When using 4.1.0 copter stable, I keep getting the following messages seen in the photos attached.
I also can’t access a lot of the QGroundcontrol features like calibrate radio etc.
Also says failed to update parameters when I change something or when I try upload a mission it says fails to upload. Even though when I check on mission planner through USB I can see the mission was uploaded and the prams changed.
Weird thing is when I roll back to 4.0.7 I am totally fine, no messages. Can save missions and Params no worries. Also 4.03 works fine.
Anything over 4.1 like 4.11 beta is also not working. So seems like a 4.1 incompatibility with QGroundcontrol?
Thing is I’m busting to use 4.1 and I don’t want to stay on 4.0.7.
qgrouncontrol version is 4.1.1
Also posted on QGrouundcontrol forum, hoping someone here might have any insight,
Thanks we are using it on android at the moment. So perhaps an issue specific to android. Have noticed the loss rate on mavlink slowly climbs up to 44% on 4.1 but stays around 19-20 % on 4.07
Strange that it would change with firmware update??
