I recently had one of the problems that Chris described, the turbine was hanging on start and not accelerating the Ng which causes Excessive EGT temps. It will melt the engine down if you don’t get it shut down quickly. We were using the recommended battery and it was new with just a few cycles. Replaced it with a rather expensive battery with twice the ma rating and now it’s all good. We have two telemetry links that we moitor on startup, one is FADEC telemetry coming through the Jeti telemetry system and the second is Blue Tooth coming directly from the FADEC to a tablet that a second person is monitoring. The pilot is watching the Heli and the second person is watching engine start on the tablet. Either person can call a shutdown with no questions asked. It would be great if we were able to get FADEC telemetry to the Autopilot. But, I would always want a way to quickly override the automation and be able to bailout especially on engine start. Also, on our FADEC if the engine fails to accelerate to run and we shut is down it doesn’t automatically enter the cool down cycle, we have to cycle the starter on and off manually to cool it down. We do fly at high altitudes.
Any time you get the N2 spool glowing red you got serious engine damage and you’re looking at a hot section. I see lots of pilots over-fueling them to get faster Ng acceleration with flames on the tailpipes. Not good. Turbines are coaxed into life, ham-fisted pilots will ruin one in short order.
I like it on the RC where the Pilot in Command has control of it. You can get a hung start if you let go of the starter too early before it goes self-sustaining. Or if you have a low starter battery and exceed the max motoring time you can burn the starter/generator up. Or if you shut the engine down and don’t wait for the min ITT before attempting a restart. Advance the fuel too fast on Ng acceleration and exceed the ITT limits, Or if you got wind blowing up the tailpipes during a start. Or in flight or during spool-up if you over-torque it.
There’s any number of ways to ruin a turboshaft engine.
The upside is that the typical RC turbines will fly 250 lb helicopters no problem at all. They have incredible shaft power in a small package. And they are self-altitude compensating, where most piston engines run out of power at 6500 MSL a turbine is just starting to really run. And the higher the altitude you fly them at, the better the fuel burn is. Turbines love cold air and low atmospheric pressure where you can squirt a little fuel in, set it on fire, and get huge expansion ratio.
There’s a surprising number of ArduPilot users that I support personally now flying them for high-altitude and heavy-lift applications commercially. Not too common among hobby users because of the entry cost to turbine power.
Our problem was definitely a weak battery, we weren’t getting flames out the exhaust but the pipes would begin to lightly glow and I would immediately shut it down. Put the new battery in and it started better and cleaner than it ever has. Lesson learned !! I even had a local guy (So Called Expert) look at it and he didn’t even catch what the real problem was, It took a friend I have in California that builds 3 meter autonomous turbine Heli’s for NASA, he uses the JAKADOFSKY PRO-X Turboshafts, he got me pointed in the right direction. I’m going to look at the start timer and reduce that and maybe reduce max EGT a bit, this could also have been caught with a low voltage alarm, so now I have a second PM on the turbine battery feeding data to the autopilot. One of the reasons for having the autopilot log FADEC data would be to have a one stop location to view logs instead of having to graph stuff from three different places and then try and match everything up. That’s my wish, but I realize turbines aren’t that widely used. I know a little about coding and at some point may see if I can do it…
Well, it illustrates the issues trying to make one autonomous start. Heck, at AMA-sanctioned RC clubs pilots aren’t even allowed to fly one without a turbine endorsement from an instructor. There’s a reason for that.
Other folks have made requests for this type of thing in the past as well, with other data sources. Again, the best thing for something like that is a custom build.
Curious if your temp probe is downstream of the N2 (EGT) or downstream of Ng (ITT). There is a large temperature and pressure gradient between those two stages of the engine. If the FADEC is using EGT with ITT specs it is very easy to over-temp the N2 spool. Like a PT6 idling at 470C ITT, you can lay your hand on the tailpipes without getting burned. A good portion of the heat is extracted in the N2 power turbine and converted to shaft power.
This would be another issue with trying to autonomous start one. Some use EGT, some use ITT, some use TIT downstream of the combustors/upstream of the Ng turbine, and the temperature and pressures drop at each stage of any turbine engine. The flame from the combustors never actually touches any part of the engine internally, including the combustor liners. If it does, that’s what causes the damage.
Well Chris, I have no idea without looking it up, that’s a great question This is a test platform using a Wren 44, and were at 6000’, on a hot day density altitude easily reaches 10000’, it has a 3 blade main and 3 blade tail rotor. The tail has 130mm blades so it has plenty of authority.
Ok, nuff said. Wren 44i/50i is ITT, but they call it EGT on the DT.
Guys can we take the turbine starting discussion to another thread?
Sorry Rob, will do. I was thinking the same thing. I apologize!
Is there any way a admin could move the turbine stuff to a new thread, maybe named Turbine Heli’s ?
Trad Heli Users,
AC 4.0 rc 3 was released yesterday. here is the post. There was significant change that I wanted to pass along. I put the IM_STAB_COL parameters in percent rather than percent * 10. when you upgrade to AC 4.0, the parameter will be converted automatically
Other changes were strictly to the parameter display names and descriptions. @ChrisOlson has been working on QGC to make the heli page compatible with AC 4.0. I will be working with @Michael_Oborne to make the heli page in mission planner usable again. I don’t expect that will be ready right away. I am working with Michael to update the page layout.
Lastly the SITL version of autonomous autorotation was merged with AC 4.0. For now it only works on SITL with Realflight and @IAMMATT has it performing the entry and glide. He is currently working on the flare algorithm and control logic.
that is all for now.
I have QGC’s heli setup mostly done, and that is in the Daily Builds at present for 4.0 rc’s. I had to put a version control in QGC because 4.0 is not compatible with 3.6. So for helicopters running 4.0 or newer the heli setup will display in the next-gen QGC ground station, but it won’t display if the firmware version is 3.6.x or earlier. For helicopters running ver 3.6.x you will have to use the current QGC stable build.
I will also prepare a couple short video presentations for the ArduPilot channel and wiki explaining the new swashplate and throttle/governor setups. I think the PR is in for the latest param description improvements, so should be able to get to that when the XML is updated in QGC.
I asked this in another traditional heli forum but I tried version 4 and had to roll back because of missing RSC channel 8 throttle control missing in ver4. In the latest version of firmware (arducopter trad heli), with the latest QGC there is no longer an option to set channel 8 to throttle output so I can tie it to a knob. I rolled back to QGC 3.5.6 and it returned, but I had to re-flash the older firmware (arducopter-heli-stable-3.6.12) manually (which I dont like doing, I like QGC to find the fmuv2 version on its own as its safer than manual updates).
Is there any reason for this change and I missed the note somewhere? I cannot use arducopter without this ability and I tried to map it through the full param list but it didnt work. I left it on the older QGC and older firmware but ideally I would like to use the latest version.
Hi Josh,
We changed the name in 4.0 because it is no longer tied to channel 8. It is now called RC passthrough. The user now has the option on setting the RC channel for the motor interlock and the RSC passthrough mode follows that assignment where as in 3.6 it remained tied to rc channel 8.
Thanks Bill, I figured there was a reason but I couldn’t get it working. I originally tried the passthrough but no luck. What do I need to change with my config to get it working? If I set it to passthrough with my radio programmed to use channel 8 (tied to knob) same as in the older firmware but it doesn’t work so I’m missing something somewhere. Rolling back to the previous version works perfectly with the same radio config so I don’t understand how to get it working.
You have to set the RC Option for channel 8 to motor interlock.
It didn’t upgrade with the firmware and I had no throttle output. I did the firmware upgrade exactly as I do all firmware upgrades, the firmware upgraded without issues or errors and I had no problems with the firmware update but it didn’t have any throttle output. After I couldn’t get it working with the normal config (that works fine on the older firmware), I tried everything, using all RSC options in the new 4.0, I even setup a new model in my radio. Nothing worked until I rolled back to the previous firmware (using the original radio model), then without making any changes it worked fine but only on the older firmware.
So if you are still having problems then send me a param file after the upgrade to 4.0.2
Will do when I have time to go through the upgrade process again. Currently I’m on copter, stable-3.6.12 without any problems (using the previous version of QGC). When I’m ready to test again, I’ll go through the firmware update and send you the param file.
I did the updates to QGC for 4.0. I deliberately made the 4.0 version of QGC incompatible with 3.6.12 and earlier firmware due to too many changes in the settings.
I will double-check it to make sure I didn’t accidentally leave something out in QGC. It was some weeks ago when I did those updates and I had bench-tested every setting to make sure it sets the proper parameters. But I will double check it again.
