The current firmware is 4.2v. The engine is using a 100CC 2-cylinder. The temperature of each engine is measured and displayed on the MISSIONPLANER screen.
I use the PT500 temperature sensor, and use a module to convert the resistance signal of PT500 into a linear voltage signal, and then connect it to the current pin of the voltage sensor, so that the temperature data can be displayed at the current position on MP
