In FBWA mode, full aileron deflection on the transmitter corresponds to a desired roll angle of 25 degrees, instead of the 60 degrees set in lim_roll_cd. I have looked through the parameter list and can’t find anything that could be limiting the roll to 25 degrees. Both the radio calibration menu and the servo outputs menu show full range when in manual mode. What could be causing this?
