I put a Matek M8Q-5883 on a mast on my 4" Flywoo Explorer. It runs great with iNav, but I really want to go full ArduCopter. I’ll pull that trigger once I finish building Ardupilot on my Timber float plane!
Interestingly, I thought the larger quads were harder to tune? Your post seems to state the opposite.
I think that whilst it appeals to a different group of users than racers or freestyle quads, a 3D printed reference frame would be welcomed by the community, particularly if it makes it easier to mount things like gps, lidar, cameras etc.
James,Brandon and Andy,I think it would be good one done with Brandon’s frame as Andy can have a nice range of setup’s to accomodate our different flying ambitions,as now I will be building an other Ardu Long range 7 inch and was going to chat up that lovely Brandon for one of his new frames
Flex is overcome by design and does not have much to do with plastic. I use a three layer wall with a custom infill very close to the honeycomb substrate we use in planes. Curves tend to be stronger why the uni bodys are up and coming trend. I like to show this 7" PRP with the Location one. Dropbox - Loc1.mp4 - Simplify your life
I also have a smaller version of this frame that could be fun I be happy to add Dropbox - bluewave.mp4 - Simplify your life
small quadcopters are much more difficult due to the small frames which transmit a lot of vibrations. even mini-solders are more difficult. also the FC 20 * 20mm which support arducopter are few
A low vibration frame helps i am sure. I think it boils down to this the 5" to 7" props suffer from roll vibration and that would be normal pre tune performance I would hope for. No secret just reduce the gains manually inreal time BTW, then if you like you can run what ever filter that floats your boat for weeks on end after you fly it.
with the 5 “I had no difficulty following the wiki. the difficulties start with 3” and even more, with 2 “. If you need to build quads under 250 grams, the 3” are the preferred choice. Nice quad your 3d frame
I think anyone that is working as a builder or instructor should own a 3D printer in this day and age they are overall fun to use and simple to assemble.
I have a 5" Badger DJI Ed. with a Matek CAN GPS and H743-SLIM fc ready to support the project. Currently, I can’t get it stable. Hopefully this process will help.
