similar in my case cant make this version to open , here are the logs , appreciate any hint om what the cause may be.
2019-06-12 13:52:36,511 INFO Program - ******************* Logging Configured ******************* (:0) [1]
2019-06-12 13:52:37,373 INFO Program - SkiaLoaded (:0) [1]
2019-06-12 13:52:37,766 DEBUG Program - Loaded: Accessibility, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a (:0) [1]
2019-06-12 13:52:40,174 DEBUG Program - Loaded: GMap.NET.WindowsForms, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null (:0) [1]
2019-06-12 13:52:40,268 DEBUG Program - TypeResolve Failed: Mono.Runtime from MissionPlanner.Utilities, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null (:0) [1]
2019-06-12 13:52:40,717 INFO Program - 64bit os False, 64bit process False (:0) [1]
2019-06-12 13:52:41,006 DEBUG Program - Loaded: System.Reactive, Version=4.0.0.0, Culture=neutral, PublicKeyToken=94bc3704cddfc263 (:0) [Base Thread]
2019-06-12 13:52:41,272 DEBUG Program - Loaded: GMap.NET.Drawing, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null (:0) [Base Thread]
2019-06-12 13:52:41,406 DEBUG Program - Loaded: SvgNet, Version=1.0.0.0, Culture=neutral, PublicKeyToken=38326cb7e06851fc (:0) [Base Thread]
2019-06-12 13:52:41,591 DEBUG Program - Loaded: ProjNET, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null (:0) [Base Thread]
2019-06-12 13:52:41,691 DEBUG Program - Loaded: GeoAPI.CoordinateSystems, Version=1.7.5.0, Culture=neutral, PublicKeyToken=a1a0da7def465678 (:0) [Base Thread]
2019-06-12 13:52:41,711 DEBUG Program - TypeResolve Failed: Mono.Runtime from MissionPlanner.ArduPilot, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null (:0) [Base Thread]
2019-06-12 13:52:41,779 DEBUG Program - Loaded: System.Speech, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35 (:0) [Base Thread]
2019-06-12 13:52:41,876 DEBUG Program - Loaded: Transitions, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null (:0) [Base Thread]
2019-06-12 13:52:41,999 DEBUG Program - Loaded: OpenTK.GLControl, Version=3.0.1.0, Culture=neutral, PublicKeyToken=bad199fe84eb3df4 (:0) [Base Thread]
2019-06-12 13:52:42,367 DEBUG Program - Loaded: OpenTK, Version=3.0.1.0, Culture=neutral, PublicKeyToken=bad199fe84eb3df4 (:0) [Base Thread]
2019-06-12 13:52:42,425 INFO MissionPlanner.MainV2 - Mainv2 ctor (:0) [Base Thread]
2019-06-12 13:52:42,431 INFO MissionPlanner.MainV2 - Loading config (:0) [Base Thread]
2019-06-12 13:52:42,568 DEBUG Program - Loaded: MissionPlanner.Strings, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null (:0) [Base Thread]
2019-06-12 13:52:42,748 DEBUG Program - Loaded: SkiaSharp.Views.Desktop, Version=1.68.0.0, Culture=neutral, PublicKeyToken=0738eb9f132ed756 (:0) [Base Thread]
2019-06-12 13:52:43,455 DEBUG Program - Loaded: SkiaSharp, Version=1.68.0.0, Culture=neutral, PublicKeyToken=0738eb9f132ed756 (:0) [Base Thread]
2019-06-12 13:52:44,005 DEBUG Program - Loaded: BSE.Windows.Forms, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null (:0) [Base Thread]
2019-06-12 13:52:44,254 DEBUG Program - Loaded: ZedGraph, Version=5.1.5.27728, Culture=neutral, PublicKeyToken=null (:0) [Base Thread]
2019-06-12 13:52:44,604 DEBUG Program - Loaded: ObjectListView, Version=2.5.1.30870, Culture=neutral, PublicKeyToken=b1c5bf581481bcd4 (:0) [Base Thread]
2019-06-12 13:52:44,811 DEBUG Program - Loaded: Microsoft.Win32.Registry, Version=4.1.1.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a (:0) [Base Thread]
2019-06-12 13:52:44,849 DEBUG Program - TypeResolve Failed: Mono.Runtime from MissionPlanner.Utilities, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null (:0) [Base Thread]
2019-06-12 13:52:44,856 INFO MissionPlanner.Utilities.srtm - .cctor (:0) [Base Thread]
2019-06-12 13:52:45,117 INFO MissionPlanner.Utilities.srtm - C:\ProgramData\Mission Planner\srtm (:0) [Base Thread]
2019-06-12 13:52:45,118 DEBUG Program - TypeResolve Failed: Mono.Runtime from MissionPlanner, Version=1.3.7054.36584, Culture=neutral, PublicKeyToken=null (:0) [Base Thread]
2019-06-12 13:52:45,122 INFO MissionPlanner.Utilities.srtm - requestRunner start (:0) [SRTM request runner]
2019-06-12 13:52:45,124 DEBUG Program - TypeResolve Failed: Mono.Runtime from MissionPlanner, Version=1.3.7054.36584, Culture=neutral, PublicKeyToken=null (:0) [Base Thread]
2019-06-12 13:52:45,130 INFO MissionPlanner.Utilities.Speech - TTS: init, mono = False (:0) [Base Thread]
2019-06-12 13:52:45,287 INFO MissionPlanner.MainV2 - Create FD (:0) [Base Thread]
2019-06-12 13:52:45,348 INFO MissionPlanner.GCSViews.FlightData - Ctor Start (:0) [Base Thread]
2019-06-12 13:52:45,748 DEBUG Program - Loaded: System.Drawing.Common, Version=4.0.0.1, Culture=neutral, PublicKeyToken=cc7b13ffcd2ddd51 (:0) [Base Thread]
2019-06-12 13:52:45,811 DEBUG Program - TypeResolve Failed: Mono.Runtime from OpenTK, Version=3.0.1.0, Culture=neutral, PublicKeyToken=bad199fe84eb3df4 (:0) [Base Thread]
2019-06-12 13:52:45,949 DEBUG Program - FirstChanceException in: OpenTK (:0) [Base Thread]
System.DllNotFoundException: Unable to load DLL ‘libEGL.dll’: The specified module could not be found. (Exception from HRESULT: 0x8007007E)
at OpenTK.Platform.Egl.Egl.GetCurrentContext()
at OpenTK.Platform.Egl.Egl.get_IsSupported()
2019-06-12 13:52:46,334 DEBUG Program - Loaded: Microsoft.GeneratedCode, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null (:0) [Base Thread]
2019-06-12 13:52:47,203 DEBUG Program - TypeResolve Failed: Mono.Runtime from GMap.NET.Core, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null (:0) [Base Thread]
2019-06-12 13:52:47,404 DEBUG Program - Loaded: GeoUtility, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null (:0) [Base Thread]
2019-06-12 13:52:48,220 DEBUG Program - FirstChanceException in: mscorlib (:0) [Base Thread]
System.Reflection.AmbiguousMatchException: Ambiguous match found.
at System.RuntimeType.GetPropertyImpl(String name, BindingFlags bindingAttr, Binder binder, Type returnType, Type[] types, ParameterModifier[] modifiers)
2019-06-12 13:52:49,371 INFO MissionPlanner.GCSViews.FlightData - Components Done (:0) [Base Thread]
2019-06-12 13:52:49,378 INFO MissionPlanner.GCSViews.FlightData - Tunning Graph Settings (:0) [Base Thread]
2019-06-12 13:52:49,424 INFO MissionPlanner.GCSViews.FlightData - HUD Settings (:0) [Base Thread]
2019-06-12 13:52:49,487 INFO MissionPlanner.ArduPilot.Common - getModesList Called (:0) [Base Thread]
2019-06-12 13:52:49,516 DEBUG Program - Loaded: System.Xml.Linq, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089 (:0) [Base Thread]
2019-06-12 13:52:49,679 DEBUG Program - FirstChanceException in: System.Xml (:0) [Base Thread]
System.Xml.XmlException: The ‘{’ character, hexadecimal value 0x7B, cannot be included in a name. Line 105, position 14.
at System.Xml.XmlTextReaderImpl.Throw(Exception e)
2019-06-12 13:52:49,692 ERROR MissionPlanner.Utilities.ParameterMetaDataRepositoryAPM - System.Xml.XmlException: The ‘{’ character, hexadecimal value 0x7B, cannot be included in a name. Line 105, position 14.
at System.Xml.XmlTextReaderImpl.Throw(String res, String[] args)
at System.Xml.XmlTextReaderImpl.Throw(Int32 pos, String res, String[] args)
at System.Xml.XmlTextReaderImpl.ParseElement()
at System.Xml.XmlTextReaderImpl.ParseElementContent()
at System.Xml.XmlTextReaderImpl.Read()
at System.Xml.Linq.XContainer.ReadContentFrom(XmlReader r)
at System.Xml.Linq.XContainer.ReadContentFrom(XmlReader r, LoadOptions o)
at System.Xml.Linq.XDocument.Load(XmlReader reader, LoadOptions options)
at System.Xml.Linq.XDocument.Load(String uri, LoadOptions options)
at MissionPlanner.Utilities.ParameterMetaDataRepositoryAPM.Reload() (:0) [Base Thread]
2019-06-12 13:52:50,069 INFO MissionPlanner.GCSViews.FlightData - Graph Setup (:0) [Base Thread]
2019-06-12 13:52:50,078 INFO MissionPlanner.GCSViews.FlightData - Map Setup (:0) [Base Thread]
2019-06-12 13:52:50,079 DEBUG Program - TypeResolve Failed: Mono.Runtime from MissionPlanner.Utilities, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null (:0) [Base Thread]
2019-06-12 13:52:50,100 INFO MissionPlanner.MainV2 - Create FP (:0) [Base Thread]
2019-06-12 13:52:51,412 DEBUG Program - TypeResolve Failed: Mono.Runtime from MissionPlanner.Utilities, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null (:0) [Base Thread]
2019-06-12 13:52:51,532 INFO MissionPlanner.GCSViews.FlightPlanner - Reading MAV_CMD for ArduCopter2 (:0) [Base Thread]
2019-06-12 13:52:51,577 INFO MissionPlanner.GCSViews.FlightPlanner - updateMapType invoke req? False (:0) [Base Thread]
2019-06-12 13:52:52,592 INFO MissionPlanner.MainV2 - Create SIM (:0) [Base Thread]
2019-06-12 13:52:52,783 DEBUG Program - FirstChanceException in: mscorlib (:0) [Base Thread]
System.IO.FileNotFoundException: Could not load file or assembly ‘MissionPlanner.Utilities.XmlSerializers, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null’ or one of its dependencies. The system cannot find the file specified.
File name: ‘MissionPlanner.Utilities.XmlSerializers, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null’
at System.Reflection.RuntimeAssembly._nLoad(AssemblyName fileName, String codeBase, Evidence assemblySecurity, RuntimeAssembly locationHint, StackCrawlMark& stackMark, IntPtr pPrivHostBinder, Boolean throwOnFileNotFound, Boolean forIntrospection, Boolean suppressSecurityChecks)
at System.Reflection.RuntimeAssembly.nLoad(AssemblyName fileName, String codeBase, Evidence assemblySecurity, RuntimeAssembly locationHint, StackCrawlMark& stackMark, IntPtr pPrivHostBinder, Boolean throwOnFileNotFound, Boolean forIntrospection, Boolean suppressSecurityChecks)
WRN: Assembly binding logging is turned OFF.
To enable assembly bind failure logging, set the registry value [HKLM\Software\Microsoft\Fusion!EnableLog] (DWORD) to 1.
Note: There is some performance penalty associated with assembly bind failure logging.
To turn this feature off, remove the registry value [HKLM\Software\Microsoft\Fusion!EnableLog].
2019-06-12 13:52:52,797 DEBUG Program - FirstChanceException in: mscorlib (:0) [Base Thread]
System.IO.FileNotFoundException: Could not load file or assembly ‘MissionPlanner.Utilities.XmlSerializers’ or one of its dependencies. The system cannot find the file specified.
File name: ‘MissionPlanner.Utilities.XmlSerializers’
2019-06-12 13:52:52,848 DEBUG Program - Loaded: Microsoft.GeneratedCode, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null (:0) [Base Thread]
2019-06-12 13:52:53,109 INFO MissionPlanner.MainV2 - Saving config (:0) [Base Thread]
2019-06-12 13:52:53,278 DEBUG Program - Loaded: WebCamService, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null (:0) [Base Thread]
2019-06-12 13:52:53,410 DEBUG Program - Loaded: DirectShowLib, Version=2.1.0.1599, Culture=neutral, PublicKeyToken=null (:0) [Base Thread]
2019-06-12 13:52:53,710 INFO MissionPlanner.MainV2 - Load Pluggins (:0) [Base Thread]
2019-06-12 13:52:53,894 DEBUG Program - Loaded: MissionPlanner.Gridv2, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null (:0) [Base Thread]
2019-06-12 13:52:53,900 INFO MissionPlanner.Plugin.PluginLoader - Plugin Load C:\Program Files\Mission Planner\plugins\MissionPlanner.Gridv2.dll (:0) [Base Thread]
2019-06-12 13:52:53,905 INFO MissionPlanner.Plugin.PluginLoader - Plugin Init Grid 0.1 by Michael Oborne (:0) [Base Thread]
2019-06-12 13:52:53,907 INFO MissionPlanner.Plugin.PluginLoader - Plugin Load C:\Program Files\Mission Planner\plugins\MissionPlanner.Gridv2.dll time 0.1721253 s (:0) [Base Thread]
2019-06-12 13:52:54,024 DEBUG Program - Loaded: MissionPlanner.SimpleGrid, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null (:0) [Base Thread]
2019-06-12 13:52:54,034 INFO MissionPlanner.Plugin.PluginLoader - Plugin Load C:\Program Files\Mission Planner\plugins\MissionPlanner.SimpleGrid.dll (:0) [Base Thread]
2019-06-12 13:52:54,038 INFO MissionPlanner.Plugin.PluginLoader - Plugin Init SimpleGrid 0.1 by Michael Oborne (:0) [Base Thread]
2019-06-12 13:52:54,041 INFO MissionPlanner.Plugin.PluginLoader - Plugin Load C:\Program Files\Mission Planner\plugins\MissionPlanner.SimpleGrid.dll time 0.1321789 s (:0) [Base Thread]
2019-06-12 13:52:54,145 DEBUG Program - Loaded: MissionPlanner.Stats, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null (:0) [Base Thread]
2019-06-12 13:52:54,146 INFO MissionPlanner.Plugin.PluginLoader - Plugin Load C:\Program Files\Mission Planner\plugins\MissionPlanner.Stats.dll (:0) [Base Thread]
2019-06-12 13:52:54,158 DEBUG Program - FirstChanceException in: mscorlib (:0) [Base Thread]
System.IO.FileNotFoundException: Could not load file or assembly ‘MissionPlanner.Stats.XmlSerializers, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null’ or one of its dependencies. The system cannot find the file specified.
File name: ‘MissionPlanner.Stats.XmlSerializers, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null’
2019-06-12 13:52:54,174 DEBUG Program - FirstChanceException in: mscorlib (:0) [Base Thread]
System.IO.FileNotFoundException: Could not load file or assembly ‘MissionPlanner.Stats.XmlSerializers’ or one of its dependencies. The system cannot find the file specified.
File name: ‘MissionPlanner.Stats.XmlSerializers’
2019-06-12 13:52:54,198 DEBUG Program - Loaded: Microsoft.GeneratedCode, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null (:0) [Base Thread]
2019-06-12 13:52:54,280 INFO MissionPlanner.Plugin.PluginLoader - Plugin Init Stats 0.1 by Michael Oborne (:0) [Base Thread]
2019-06-12 13:52:54,281 INFO MissionPlanner.Plugin.PluginLoader - Plugin Load C:\Program Files\Mission Planner\plugins\MissionPlanner.Stats.dll time 0.2380279 s (:0) [Base Thread]
2019-06-12 13:52:54,384 DEBUG Program - Loaded: TrackerHome, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null (:0) [Base Thread]
2019-06-12 13:52:54,389 INFO MissionPlanner.Plugin.PluginLoader - Plugin Load C:\Program Files\Mission Planner\plugins\TrackerHome.dll (:0) [Base Thread]
2019-06-12 13:52:54,392 INFO MissionPlanner.Plugin.PluginLoader - Plugin Init GPS Tracker Home Plugin 1.0 by Will Bryan (:0) [Base Thread]
2019-06-12 13:52:54,394 INFO MissionPlanner.Plugin.PluginLoader - Plugin Load C:\Program Files\Mission Planner\plugins\TrackerHome.dll time 0.1081396 s (:0) [Base Thread]
2019-06-12 13:52:54,610 INFO MissionPlanner.Plugin.PluginLoader - LoadFromSameFolder MissionPlanner.Gridv2, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null-> MissionPlanner.Gridv2.resources, Version=1.0.0.0, Culture=en-US, PublicKeyToken=null (:0) [Base Thread]
2019-06-12 13:52:54,717 INFO MissionPlanner.Plugin.PluginLoader - LoadFromSameFolder MissionPlanner.Gridv2, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null-> MissionPlanner.Gridv2.resources, Version=1.0.0.0, Culture=en-US, PublicKeyToken=null (:0) [Base Thread]
2019-06-12 13:52:54,813 INFO MissionPlanner.Plugin.PluginLoader - LoadFromSameFolder MissionPlanner.Gridv2, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null-> MissionPlanner.Gridv2.resources, Version=1.0.0.0, Culture=en-US, PublicKeyToken=null (:0) [Base Thread]
2019-06-12 13:52:54,897 INFO MissionPlanner.Plugin.PluginLoader - LoadFromSameFolder MissionPlanner.Gridv2, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null-> MissionPlanner.Gridv2.resources, Version=1.0.0.0, Culture=en-US, PublicKeyToken=null (:0) [Base Thread]
2019-06-12 13:52:54,978 INFO MissionPlanner.Plugin.PluginLoader - LoadFromSameFolder MissionPlanner.Gridv2, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null-> MissionPlanner.Gridv2.resources, Version=1.0.0.0, Culture=en, PublicKeyToken=null (:0) [Base Thread]
2019-06-12 13:52:55,062 INFO MissionPlanner.Plugin.PluginLoader - LoadFromSameFolder MissionPlanner.Gridv2, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null-> MissionPlanner.Gridv2.resources, Version=1.0.0.0, Culture=en, PublicKeyToken=null (:0) [Base Thread]
2019-06-12 13:52:55,149 INFO MissionPlanner.Plugin.PluginLoader - LoadFromSameFolder MissionPlanner.Gridv2, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null-> MissionPlanner.Gridv2.resources, Version=1.0.0.0, Culture=en, PublicKeyToken=null (:0) [Base Thread]
2019-06-12 13:52:55,231 INFO MissionPlanner.Plugin.PluginLoader - LoadFromSameFolder MissionPlanner.Gridv2, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null-> MissionPlanner.Gridv2.resources, Version=1.0.0.0, Culture=en, PublicKeyToken=null (:0) [Base Thread]
2019-06-12 13:52:55,280 INFO MissionPlanner.MainV2 - Load Pluggins… Done (:0) [Base Thread]
2019-06-12 13:52:55,284 INFO MissionPlanner.MainV2 - show FlightData (:0) [Base Thread]
2019-06-12 13:52:55,319 INFO MissionPlanner.GCSViews.FlightData - Activate Called (:0) [Base Thread]
2019-06-12 13:52:55,329 DEBUG MissionPlanner.Utilities.Tracking - v=1&tid=UA-43098846-1&cid=1b74528f-3218-41da-bb9a-a24237f3246a&t=appview&an=Mission+Planner&av=1.3.66&cd=MissionPlanner.GCSViews.FlightData&dp=MissionPlanner.GCSViews.FlightData&dt=FlightData&sc=start&ul=en-US&sd=32-bits&sr=1366x768&cd1=Microsoft+Windows+NT+10.0.14393.0&cd4=4&z=600896131 (:0) [8]
2019-06-12 13:52:55,802 DEBUG MissionPlanner.Utilities.Tracking - OK (:0) [8]
2019-06-12 13:52:55,992 INFO MissionPlanner.Controls.HUD - OnLoad Start (C:\Users\mich1\Desktop\Hex\MissionPlanner\ExtLibs\Controls\HUD.cs:878) [Base Thread]
2019-06-12 13:52:56,001 INFO MissionPlanner.Controls.HUD - Vendor: Intel Corporation (C:\Users\mich1\Desktop\Hex\MissionPlanner\ExtLibs\Controls\HUD.cs:887) [Base Thread]
2019-06-12 13:52:56,003 INFO MissionPlanner.Controls.HUD - Version: 2.1 (C:\Users\mich1\Desktop\Hex\MissionPlanner\ExtLibs\Controls\HUD.cs:888) [Base Thread]
2019-06-12 13:52:56,006 INFO MissionPlanner.Controls.HUD - Device: Intel® Graphics Media Accelerator 3600 Series (C:\Users\mich1\Desktop\Hex\MissionPlanner\ExtLibs\Controls\HUD.cs:889) [Base Thread]
2019-06-12 13:52:56,008 DEBUG MissionPlanner.Controls.HUD - GetInteger (C:\Users\mich1\Desktop\Hex\MissionPlanner\ExtLibs\Controls\HUD.cs:894) [Base Thread]
2019-06-12 13:52:56,013 DEBUG MissionPlanner.Controls.HUD - MatrixMode (C:\Users\mich1\Desktop\Hex\MissionPlanner\ExtLibs\Controls\HUD.cs:896) [Base Thread]
2019-06-12 13:52:56,016 DEBUG MissionPlanner.Controls.HUD - LoadIdentity (C:\Users\mich1\Desktop\Hex\MissionPlanner\ExtLibs\Controls\HUD.cs:898) [Base Thread]
2019-06-12 13:52:56,018 DEBUG MissionPlanner.Controls.HUD - Ortho (C:\Users\mich1\Desktop\Hex\MissionPlanner\ExtLibs\Controls\HUD.cs:900) [Base Thread]
2019-06-12 13:52:56,022 DEBUG MissionPlanner.Controls.HUD - MatrixMode (C:\Users\mich1\Desktop\Hex\MissionPlanner\ExtLibs\Controls\HUD.cs:902) [Base Thread]
2019-06-12 13:52:56,025 DEBUG MissionPlanner.Controls.HUD - LoadIdentity (C:\Users\mich1\Desktop\Hex\MissionPlanner\ExtLibs\Controls\HUD.cs:904) [Base Thread]
2019-06-12 13:52:56,027 DEBUG MissionPlanner.Controls.HUD - PushAttrib (C:\Users\mich1\Desktop\Hex\MissionPlanner\ExtLibs\Controls\HUD.cs:907) [Base Thread]
2019-06-12 13:52:56,030 DEBUG MissionPlanner.Controls.HUD - Disable (C:\Users\mich1\Desktop\Hex\MissionPlanner\ExtLibs\Controls\HUD.cs:909) [Base Thread]
2019-06-12 13:52:56,033 DEBUG MissionPlanner.Controls.HUD - BlendFunc (C:\Users\mich1\Desktop\Hex\MissionPlanner\ExtLibs\Controls\HUD.cs:911) [Base Thread]
2019-06-12 13:52:56,036 DEBUG MissionPlanner.Controls.HUD - Enable (C:\Users\mich1\Desktop\Hex\MissionPlanner\ExtLibs\Controls\HUD.cs:913) [Base Thread]
2019-06-12 13:52:56,039 DEBUG MissionPlanner.Controls.HUD - Hint (C:\Users\mich1\Desktop\Hex\MissionPlanner\ExtLibs\Controls\HUD.cs:928) [Base Thread]
2019-06-12 13:52:56,043 DEBUG MissionPlanner.Controls.HUD - Enable (C:\Users\mich1\Desktop\Hex\MissionPlanner\ExtLibs\Controls\HUD.cs:944) [Base Thread]
2019-06-12 13:52:56,045 INFO MissionPlanner.Controls.HUD - OnLoad Done (C:\Users\mich1\Desktop\Hex\MissionPlanner\ExtLibs\Controls\HUD.cs:956) [Base Thread]
