# python mavproxy.py --master=/dev/ttyACM0 --baudrate 115200
http://ardupilot.github.io/MAVProxy/html/modules/relay.html
I have successfully set up mavproxy on a raspberry pi and have connected to the APM. I can turn the relay on using mission planner commands.
I sent to following command to the APM.
“relay set 0 0”
(using false or NPN logic)
The relay state does not change.
I also tried
“relay set 0 1”
The relay state did not change as well.
Is there something I’m missing?
My goal is to turn on relay 0 using mavproxy.
