Thanks Billbonney,
Glad you asked, I was just starting to try and fix some of them.
----------------------------------------- Cut Here -------------------------------------------------------
pi@rpi ~/workspace/apm_planner $ ./release/apmplanner2
INFO 2014-01-29T21:42:11.027 QGCCore::initialize()
INFO 2014-01-29T21:42:11.035 Current Build Info
INFO 2014-01-29T21:42:11.037 Git Hash: 0127cf60c4de1dea82648996d134b135e96e12a1
INFO 2014-01-29T21:42:11.042 Git Commit: 2.0.0-RC2-47-g0127cf6-DEV
INFO 2014-01-29T21:42:11.049 APPLICATION_NAME: "APM Planner"
INFO 2014-01-29T21:42:11.050 APPLICATION_VERSION: "v2.0.0 (RC2)"
ERROR! font file: :/general/vera.ttf DOES NOT EXIST!
INFO 2014-01-29T21:42:11.214 Start Link Manager
INFO 2014-01-29T21:42:11.227 Start UAS Manager
INFO 2014-01-29T21:42:11.317 UDP Created "UDP Link (port:14550)"
DEBUG 2014-01-29T21:42:11.336 Creating MainWindow
Cannot open file ‘:files/images/actions/system-log-out.svg’, because: Unknown error
Cannot open file ‘:files/images/control/launch.svg’, because: Unknown error
Cannot open file ‘:files/images/control/land.svg’, because: Unknown error
pi@rpi:~/workspace/apm_planner$
pi@rpi:~/workspace/apm_planner$ cat startup.txt
Cannot open file ‘:files/images/actions/process-stop.svg’, because: Unknown error
Cannot open file ‘:files/images/actions/list-add.svg’, because: Unknown error
Cannot open file ‘:files/images/categories/applications-system.svg’, because: Unknown error
Cannot open file ‘:files/images/devices/input-gaming.svg’, because: Unknown error
Cannot open file ‘:files/images/apps/utilities-system-monitor.svg’, because: Unknown error
Cannot open file ‘:files/images/status/software-update-available.svg’, because: Unknown error
Cannot open file ‘:files/images/categories/preferences-system.svg’, because: Unknown error
Cannot open file ‘:files/images/categories/applications-internet.svg’, because: Unknown error
Cannot open file ‘:files/images/devices/network-wired.svg’, because: Unknown error
Cannot open file ‘:files/images/status/network-wireless-encrypted.svg’, because: Unknown error
Cannot open file ‘:files/images/status/audio-volume-high.svg’, because: Unknown error
Cannot open file ‘:files/images/status/audio-volume-muted.svg’, because: Unknown error
Cannot open file ‘:files/images/devices/network-wireless.svg’, because: Unknown error
Cannot open file ‘:files/images/status/folder-drag-accept.svg’, because: Unknown error
Cannot open file ‘:files/images/apps/accessories-calculator.svg’, because: Unknown error
Cannot open file ‘:files/images/apps/utilities-terminal.svg’, because: Unknown error
Cannot open file ‘:files/images/actions/media-playback-start.svg’, because: Unknown error
INFO 2014-01-29T21:42:37.544 Creating SubMainWindow: SubMainWindow(0x234e6b0)
INFO 2014-01-29T21:42:37.547 setting objectName: "VIEW_MISSION"
QPainter::begin: Paint device returned engine == 0, type: 3
QPainter::translate: Painter not active
QPainter::scale: Painter not active
QPainter::setBackground: Painter not active
QPainter:
Painter not active, aborted
INFO 2014-01-29T21:42:39.272 Creating SubMainWindow: SubMainWindow(0x2383230)
INFO 2014-01-29T21:42:39.274 setting objectName: "VIEW_FLIGHT"
QPainter:
INFO 2014-01-29T21:42:39.827 Creating SubMainWindow: SubMainWindow(0x23a14e8)
INFO 2014-01-29T21:42:39.832 setting objectName: "VIEW_HARDWARE_CONFIG"
Cannot open file ‘:/files/images/actions/list-add.svg’, because: Unknown error
Cannot open file ‘:/files/images/actions/list-remove.svg’, because: Unknown error
Object::connect: No such slot ApmFirmwareConfig::requestFirmwares()
Object::connect: (receiver name: ‘ApmFirmwareConfig’)
DEBUG 2014-01-29T21:42:40.459 Requesting firmware: “stable” "apm"
DEBUG 2014-01-29T21:42:40.769 APM Detected
DEBUG 2014-01-29T21:42:40.792 Setting ApmFirmware link to 0
DEBUG 2014-01-29T21:42:40.795 Requesting firmware: “stable” "apm"
DEBUG 2014-01-29T21:42:41.299 fillPortsInfo
INFO 2014-01-29T21:42:41.488 Inserting "ttyAMA0"
INFO 2014-01-29T21:42:41.491 Inserting "ttyUSB0"
INFO 2014-01-29T21:42:41.494 Changed Link to: "ttyAMA0"
INFO 2014-01-29T21:42:41.682 Inserting "ttyUSB0"
INFO 2014-01-29T21:42:42.007 Creating SubMainWindow: SubMainWindow(0x25a5ef8)
INFO 2014-01-29T21:42:42.009 setting objectName: "VIEW_SOFTWARE_CONFIG"
DEBUG 2014-01-29T21:42:42.135 Disable Controls
INFO 2014-01-29T21:42:42.789 Creating SubMainWindow: SubMainWindow(0x26758b0)
INFO 2014-01-29T21:42:42.809 setting objectName: "VIEW_ENGINEER"
INFO 2014-01-29T21:42:43.024 Creating SubMainWindow: SubMainWindow(0x268dc48)
INFO 2014-01-29T21:42:43.026 setting objectName: "VIEW_MAVLINK"
Cannot open file ‘:/files/images/status/folder-open.svg’, because: Unknown error
Cannot open file ‘:/files/images/categories/applications-system.svg’, because: Unknown error
INFO 2014-01-29T21:42:43.090 Creating SubMainWindow: SubMainWindow(0x26a59d8)
INFO 2014-01-29T21:42:43.102 setting objectName: "VIEW_SIMULATOR"
QPainter:
INFO 2014-01-29T21:42:43.778 Creating SubMainWindow: SubMainWindow(0x26d3d98)
INFO 2014-01-29T21:42:43.793 setting objectName: "VIEW_TERMINAL"
DEBUG 2014-01-29T21:42:43.909 fillPortsInfo
INFO 2014-01-29T21:42:44.127 Inserting "ttyAMA0"
INFO 2014-01-29T21:42:44.144 Inserting "ttyUSB0"
INFO 2014-01-29T21:42:44.146 Changed Link to: "ttyAMA0"
DEBUG 2014-01-29T21:42:44.419 MODE: 0
DEBUG 2014-01-29T21:42:44.424 "D|PREFLIGHT"
DEBUG 2014-01-29T21:42:44.435 MODE: 80
DEBUG 2014-01-29T21:42:44.445 "D|STABILIZED"
DEBUG 2014-01-29T21:42:44.466 MODE: 64
DEBUG 2014-01-29T21:42:44.472 "D|MANUAL"
DEBUG 2014-01-29T21:42:44.485 MODE: 88
DEBUG 2014-01-29T21:42:44.490 "D|VECTOR|STABILIZED"
DEBUG 2014-01-29T21:42:44.506 MODE: 92
DEBUG 2014-01-29T21:42:44.525 "D|AUTO|STABILIZED"
DEBUG 2014-01-29T21:42:44.536 MODE: 66
DEBUG 2014-01-29T21:42:44.547 "D|TEST"
Cannot open file ‘:files/images/actions/go-bottom.svg’, because: Unknown error
Cannot open file ‘:files/images/actions/go-jump.svg’, because: Unknown error
Cannot open file ‘:/files/images/devices/network-wireless.svg’, because: Unknown error
Cannot open file ‘:files/images/actions/qgroundcontrol-connect.svg’, because: Unknown error
INFO 2014-01-29T21:42:45.269 UASActionsWidget creating UASActionsWidget(0x277a658)
DEBUG 2014-01-29T21:42:46.918 qmlBaseDir "/home/pi/workspace/apm_planner"
DEBUG 2014-01-29T21:42:46.925 QUrl( “file:///home/pi/workspace/apm_planner/qml/ApmToolBar.qml” )
DEBUG 2014-01-29T21:42:47.323 QML Status: 1
DEBUG 2014-01-29T21:42:47.417 Loading widget: "PRIMARY_FLIGHT_DISPLAY_DOCKWIDGET"
DEBUG 2014-01-29T21:42:47.426 Loading widget: "UAS_INFO_INFOVIEW_DOCKWIDGET"
DEBUG 2014-01-29T21:42:50.664 LinkManager::Add UDPLink(0x22cd7e8) Thread QThread(0x225e950)
DEBUG 2014-01-29T21:42:50.707 Sucess: Added UDPLink(0x22cd7e8)
DEBUG 2014-01-29T21:42:50.767 LinkManager::addProtocol link: UDPLink(0x22cd7e8) protocol MAVLinkProtocol(0xb0be7008)
INFO 2014-01-29T21:42:50.819 ADDED LINK TO PROTOCOL “UDP Link (port:14550)” “MAVLink protocol” protocolLinks.size: 1 Links.size: 1
DEBUG 2014-01-29T21:42:51.006 LinkManager::Add UDPLink(0x22cd7e8) Thread QThread(0x225e950)
DEBUG 2014-01-29T21:42:51.087 duplicate (not added) UDPLink(0x22cd7e8)
INFO 2014-01-29T21:42:51.837 create SerialLink: Load Previous Settings
INFO 2014-01-29T21:42:51.907 “ttyUSB0” 57600 0 0 8 1
DEBUG 2014-01-29T21:42:51.953 LinkManager::Add SerialLink(0x2bbd130) Thread QThread(0x225e950)
DEBUG 2014-01-29T21:42:51.998 Sucess: Added SerialLink(0x2bbd130)
DEBUG 2014-01-29T21:42:52.075 APMToolBar: new Serial Link Created SerialLink(0x2bbd130)
DEBUG 2014-01-29T21:42:52.159 APMToolBar: updateLinkDisplay
DEBUG 2014-01-29T21:42:52.288 APMToolBar setConnection: false
DEBUG 2014-01-29T21:42:52.306 LinkManager::addProtocol link: SerialLink(0x2bbd130) protocol MAVLinkProtocol(0xb0be7008)
INFO 2014-01-29T21:42:52.351 ADDED LINK TO PROTOCOL “ttyUSB0” “MAVLink protocol” protocolLinks.size: 2 Links.size: 2
DEBUG 2014-01-29T21:42:52.572 LinkManager::Add SerialLink(0x2bbd130) Thread QThread(0x225e950)
DEBUG 2014-01-29T21:42:52.579 duplicate (not added) SerialLink(0x2bbd130)
DEBUG 2014-01-29T21:42:52.903 SCW: Link is connected false
INFO 2014-01-29T21:42:53.218 current portName "ttyUSB0"
INFO 2014-01-29T21:42:53.236 setPortName to ""
INFO 2014-01-29T21:42:53.265 current portName "ttyUSB0"
INFO 2014-01-29T21:42:53.280 setPortName to ""
INFO 2014-01-29T21:42:54.933 UDPLink::UDP connect
DEBUG 2014-01-29T21:42:55.210 firmwareListFinished error: 0 "Unknown error"
DEBUG 2014-01-29T21:42:55.289 firmwareListFinished error: 0 "Unknown error"
DEBUG 2014-01-29T21:42:55.327 firmwareListFinished error: 0 "Unknown error"
DEBUG 2014-01-29T21:42:55.379 firmwareListFinished error: 0 "Unknown error"
DEBUG 2014-01-29T21:42:55.467 firmwareListFinished error: 0 "Unknown error"
DEBUG 2014-01-29T21:42:55.550 firmwareListFinished error: 0 "Unknown error"
DEBUG 2014-01-29T21:42:55.579 firmwareListFinished error: 0 "Unknown error"
DEBUG 2014-01-29T21:42:55.680 firmwareListFinished error: 0 "Unknown error"
DEBUG 2014-01-29T21:42:55.768 firmwareListFinished error: 0 "Unknown error"
DEBUG 2014-01-29T21:42:55.878 firmwareListFinished error: 0 "Unknown error"
DEBUG 2014-01-29T21:42:55.930 firmwareListFinished error: 0 "Unknown error"
DEBUG 2014-01-29T21:42:55.989 firmwareListFinished error: 0 "Unknown error"
DEBUG 2014-01-29T21:42:56.084 firmwareListFinished error: 0 "Unknown error"
DEBUG 2014-01-29T21:42:56.134 firmwareListFinished error: 0 "Unknown error"
DEBUG 2014-01-29T21:42:56.149 firmwareListFinished error: 0 "Unknown error"
DEBUG 2014-01-29T21:42:56.208 firmwareListFinished error: 0 "Unknown error"
DEBUG 2014-01-29T21:42:56.250 firmwareListFinished error: 0 "Unknown error"
DEBUG 2014-01-29T21:42:56.320 firmwareListFinished error: 0 "Unknown error"
DEBUG 2014-01-29T21:42:57.208 LinkManager::Add UDPLink(0x22cd7e8) Thread QThread(0x225e950)
DEBUG 2014-01-29T21:42:57.260 duplicate (not added) UDPLink(0x22cd7e8)
DEBUG 2014-01-29T21:42:57.395 LinkManager::addProtocol link: UDPLink(0x22cd7e8) protocol MAVLinkProtocol(0xb0be7008)
INFO 2014-01-29T21:42:57.517 ADDED LINK TO PROTOCOL “UDP Link (port:14550)” “MAVLink protocol” protocolLinks.size: 2 Links.size: 2
DEBUG 2014-01-29T21:42:57.640 LinkManager::Add SerialLink(0x2bbd130) Thread QThread(0x225e950)
DEBUG 2014-01-29T21:42:57.689 duplicate (not added) SerialLink(0x2bbd130)
DEBUG 2014-01-29T21:42:57.763 LinkManager::addProtocol link: SerialLink(0x2bbd130) protocol MAVLinkProtocol(0xb0be7008)
INFO 2014-01-29T21:42:57.834 ADDED LINK TO PROTOCOL “ttyUSB0” “MAVLink protocol” protocolLinks.size: 2 Links.size: 2
----------------------------------------- Cut Here --------------------------------------------------------------------------------
There are many “Cannot open file *” messages, I get missing icons for example on the “Firmware install screen” there’s no icons associated with each of vehicle types. ?
I tried changing a few of them from ‘:/files/*’ to ‘:files/’ it didn’t fix anything. So if you see wrong locations, they are likely my changes.
I also get a message about the vera.ttf font, I’m sure that’s easily solved.
Thanks
Andy
