I am having stability issues with APM Planner. Is that the reccommended ground station application or should I be using Mission Planner? I have only tried to use APM Planner so far, and i am not having the best experience. I have tried it under the following scenario’s:
-On windows 7 system
-On ubuntu VM within Windows 7 system
-on ubuntu system
-on windows 7 VM under ubuntu
I probably launched it 25 times on windows 7 and it crashed at some point at least 1/2 the time.
I probably launched it 10 times on all the other scenarios and although a little more stable, still have frequent crashes.
Is this a common thing? What is the best/preferred/most tested version that we should be using? Is there a minimum hardware configuration that should be followed?
I was using the version linked on the main site assuming it was the most “stable” and “supported”. I will try the latest beta build and see how it goes.
Are the functions identical between the 2 versions (MP v. APM Planner) and as functions are added are they added to both?
