[quote=“driedeker”]does not run on my win 7 ult 64 ,
when started windows tells me it has stopped working,have run as admin and not as admin,both say the same.?[/quote]
Can you post up your application log files? They are located in C:\Users\YOURUSERNAME\apmplanner2, and are log.txt, log.txt.1 log.txt2 etc. Either via pastebin, or another file sharing service?
[quote=“malcom2073”][quote=“driedeker”]does not run on my win 7 ult 64 ,
I also have complete failure on my windows 7 Pro system when trying to start APM planner 2
“apmplanner2,exe has stopped working”
Each attempt results in same text file seen below:
INFO 2014-01-10T20:36:12.022 QGCCore::initialize()
INFO 2014-01-10T20:36:12.068 Current Build Info
INFO 2014-01-10T20:36:12.069 Git Hash: 2999f16e7587efe48caa7bcfa6ff5dab67a8eea9
INFO 2014-01-10T20:36:12.069 Git Commit: 2.0.0-RC1-1-g2999f16
INFO 2014-01-10T20:36:12.069 APPLICATION_NAME: "APM Planner"
INFO 2014-01-10T20:36:12.069 APPLICATION_VERSION: "v2.0.0 (RC1)"
INFO 2014-01-10T20:36:12.129 Start Link Manager
INFO 2014-01-10T20:36:12.131 Start UAS Manager
INFO 2014-01-10T20:36:12.144 UDP Created "UDP Link (port:14550)"
DEBUG 2014-01-10T20:36:12.145 Creating MainWindow
INFO 2014-01-10T20:36:12.341 Creating SubMainWindow: SubMainWindow(0x4da6fa8)
INFO 2014-01-10T20:36:12.341 setting objectName: “VIEW_MISSION”
Brings up small APM 2.0 Splash window and then small blank CLI type (black background) window.
I will ask MichaelC to look into this. We have another instance of this happening on startup on Windows. I’m not sure how far he is with a resolution, but it’s being actively investigated. Thx
Are you running 64 or 32 bit? Do you have any other Qt based applications installed like iPython?
