Hi all,
I finally managed to flash my APM 2.8, now i move onto calibration. I don’t have a USB cable long enough so thought i would perform the calibration using the Telemetry units. I can talk to the APM ok with a direct serial cable using the only serial port available USBMODEM631 at 115200 baud. I thought the telemetry units would be just a radio replacement for the usb cable. In APM planner if i select the same serial port and set baud at 57600 it just says unable to open file etc. the Radios are paired ok with a solid green LED on both and a flash red every now and then on the quadcopter unit. Do i need another FTDI driver for the telemetry unit on the MAC ?.
Thanks
Andy
