APM Planner 2 wont connect
Got my Pixhawk today :smiley: APM Planner 2 wont connect to my Pixhawk. It does upload the firmware to it though. Top-right of the screen says “NO DEVICE”. Ive tried this on 2 computers with the same results, Win7 and XP.
Mission planner does connect though, no problem.
Joly
jolyboy: I believe this is the same issue someone was having previously. If you type anything where the COM port selection is in the connection dialog (found when you click the com port or baud rate), and then re-select the proper port from the drop down it should work. This is an issue on computers with no default COM port. There will be a fix for this in the next release.
I was having that same problem and that did work for me thank you!!!
JFC
(Pixhawk, Macbook pro, AMP 2.0 with latest update loaded)
