Unfortunately the XML file gets updated to its original values every time APM Planner 2 restarts. The top of the file says that the parameters were generated with a script called param_parse.py, but I can’t find that script anywhere.
I don’t know about this script either - perhaps I can show you the place in APM Planner where you can disable the downloading - I will have a look at the code this evening.
Perhaps @billb has another Idea how to deal with this.
Hello
I am trying to change the mode of the ardupilot software to the loiter mode. I am controlling the pixhawk using the mavlink protocol. I am able to change the mode to the loiter mode using the mavlink protocol.
Now i want to send the signal to the ground station (apmplanner2 in my case) to give me an alert that the mode has been changed. I know by default thr are some alerts that it will say the mode has been changed to loitor. Are thr any custom alerts/warning messages which i can use? How do i add a customer message on the ground station and send the command from mavlink to hear that alert?
