On OSX I had to alter Makefile INCPATH from -I/Library/Frameworks/GStreamer.framework/Headers to -I/Library/Frameworks/GStreamer.framework/Versions/1.0/Headers to get past missing gst.h errors.
Now, I get:
In file included from src/VideoStreaming/VideoSurface.cc:31:
In file included from src/VideoStreaming/VideoSurface_p.h:33:
In file included from src/VideoStreaming/VideoSurface.h:33:
In file included from /Users/fnoop/Qt/5.5/clang_64/lib/QtCore.framework/Headers/QObject:1:
In file included from ../../../Qt/5.5/clang_64/lib/QtCore.framework/Headers/qobject.h:41:
/Users/fnoop/Qt/5.5/clang_64/lib/QtCore.framework/Headers/qstring.h:739:55: error: no type named 'u16string' in namespace 'std'
In file included from src/VideoStreaming/VideoReceiver.cc:30:
In file included from src/VideoStreaming/VideoReceiver.h:33:
In file included from ../../../Qt/5.5/clang_64/lib/QtCore.framework/Headers/QObject:1:
static inline QString fromStdU16String(const std::u16string &s);
Changing the default compiler from gcc to clang in QT Creator prefs and then running the compile from QT Creator seems to go better, I had no luck from the command line.
I’m using macOS Sierra, QT 5.5.1, xCode 8.
You need to make sure you clean your build, if you are getting anywhere it would indicate you have prebuilt on OSX 10.11 before updating to macOS 10.12 (sierra)
If using pre-built install of Qt made with clang, you need to use clang. If you download and install gcc you’ll need to rebuild Qt from source (I don’t recommend that unless you up for a challenge!)
I am involved in the GCS development project.
So I tried running the program you uploaded but I could not see the video image.
My RPi3 uses RTSP to provide images at the address of rtsp: //xxx.xxx.xxx.xxx:8554/test.
When you run the program, you can see the following message in the application output that appears: (into QT-Creator)
[20170207 21:38:27.742 DEBUG] - QUrl(“file:///root/dmkimGCS/build-apm_planner-APM_Planner-Debug/debug/qml/PrimaryFlightDisplayQML.qml”)
[20170207 21:38:27.808 WARN ] - file:///root/dmkimGCS/build-apm_planner-APM_Planner-Debug/debug/qml/components/RollPitchIndicator.qml:59:22: Unable to assign [undefined] to VideoSurface*
[20170207 21:38:27.808 WARN ] - file:///root/dmkimGCS/build-apm_planner-APM_Planner-Debug/debug/qml/PrimaryFlightDisplayQML.qml:80: ReferenceError: videoReceiver is not defined
[20170207 21:38:27.808 WARN ] - file:///root/dmkimGCS/build-apm_planner-APM_Planner-Debug/debug/qml/PrimaryFlightDisplayQML.qml:79: ReferenceError: videoDisplay is not defined
[20170207 21:38:27.809 DEBUG] - QML Status: QQuickView::Status(Ready)
[20170207 21:38:27.809 WARN ] - file:///root/dmkimGCS/build-apm_planner-APM_Planner-Debug/debug/qml/PrimaryFlightDisplayQML.qml:80: ReferenceError: videoReceiver is not defined
[20170207 21:38:27.809 ERROR] - Failed to create qtquick2videosink. Make sure it is installed correctly
Could you answer the solution to this problem?
Also, when you run the program, can you show me the Application output message? (To compare with my message …)
I have been working with the help of some previous answers, but I am very sorry to bother you with questions again.
