Hi again,
I can’t figure this out. I can plan a simple mission and put a uncertainty radius of 5 and a yaw angle of 90 on a waypoint. I then press the set button and change tabs to the onboard way points, press the “refresh” button, and I can see there is no yaw or radius in the text line. when I pull it back into the editor using the “get” button, the radius and yaw angle are zero.
also it says “rotary wing only” when I hover the cursor over the yaw angel box. I was working fine just a couple of days ago. I have re-loaded the IrIs parameters and it is set to V-style and went through the required setup again.
this happens on both PC and Mac.
I am setting up a traditional heli with a Pixhawk and I am using the same computers for the setup. Is it OK to use the same computer with multiple PixHawk controllers??
or is that a no-no.
thanks for your time
Bobby
