I saw post on diydrones that was removed on getting the hud working in apm planner.
If anyone has it working can they share how they got it to…
I installed from scratch apm planner with gstreamer1.0 and
its libraries and confirmed that on qmake it was being built with video.
I don’t see any options for entering gstreamer commands in apm planner?
The cached link I found says to enter:
gst-launch-1.0 videotestsrc ! x264enc ! rtph264pay ! udpsink host=127.0.0.1 port=5000
I did this via terminal in the background thinking maybe it would work(I entered my own IP address)
I am using a raspi on the other end and can confirm that I have gstreamer working
entering a different command but I would like to have the video show up with the HUD.
I had a problem with the builds (windows/osx) (one being it was really two large for our download packages!) I need to work on it to fix it so it can be dependent on if the user has gstreamer installed or not. You need to install gstreamer on your platform for it to work.
You just need to enter this on the rapsi
This code was for testing on the desktop (and it also verifies you have gstreamer installed correctly on the desktop
Hope that helps
Hopefully I have some time to fix the builds soon so we can release this to the larger public. (That said I may do a handbuilt bundle for OSX to see interest)
I’m still having problems…I did the sample gst-launches where it opens a ball(in separate window) but it is never opened in the apm planner regardless of what ip/port i use
also the primary flight display is blank.
I am struggling to see what to do once I have apm planner running.
I’ve the same problem: my HUD is blank.
I download the project today but nothing has changed.
I’ve installed it on a PC with Ubuntu 14.04.3 32bit and on the same PC with Ubuntu 14.04.3 64bit with the same final result.
Before compile the entire project I’ve installed gstreamer1.0* and libgstreamer1.0* as you suggested in your readme file.
Another strange thing has happend: when I’m trying to connect my pixhawk (with no calibration) APM crashes.
What’s wrong?
What can I try?
