the apm was working fine till day before yesterday . I tried installing the firmware today and it failed with this message “Failed to download new firmware : System.argumentException : The given port name does not start with COM/com or does not resolve to a valid serial port …” .
I tried it on a different laptop and still the same error
I checked in the device manager COM port is not showing.
i have no clue whats going on . Is it a minor or a major issue?
In the APM the green power light is on and the red gyro light keeps blinking
Hey man
i have exactly the same error, red light freezed, green light blinking. In addition to 404 error on loading maps…i will keep you updated about any solution
[quote=“vi123”]the apm was working fine till day before yesterday . I tried installing the firmware today and it failed with this message “Failed to download new firmware : System.argumentException : The given port name does not start with COM/com or does not resolve to a valid serial port …” .
In the APM the green power light is on and the red gyro light keeps blinking[/quote]
Do you found something?
Check on upper right corner the comunicating port, and switch from auto to the com port in use…
For me, worked
