APM compass wont calibrate on the Hex X 375mm unless i remove it completely what is the solution here is there a flight mode i can use in APM that doesn’t require a compass
If i calibrate it off the Hex its fine then i place it on the Hex and it says bad compass.
My only other solution here is to throw APM in the bin and find something else.
