HI All.
I just need confirmation as to the plausible reasons for this failure.
Hope someone can help me analyze the attached logs.
QUick run down - i took off in Stabalize mode, switched to Alti Mode, and after a slight increase in altitude while in Alti Mode, it fell and rolled a few times.
You help will be greatly appreciated.
Thanks,
Jared
SO - I finally got my quad off the ground again…and Ive had a few low to ground test flights.
Today i decided to recheck all for vibrations etc, test Alti Hold and Loiter.
Alti hold definitely needs some tuning - all bouncy…But I then wanted to just fly normally without any modes and before i go much higher - the quad decided to ROLL and fall!
PLEASE can someone help me look at the logs.
I wont be lifting this anytime soon until i find the EXACT reason!
I was under the impression that my first fall was as a result of a failed prop…but this time - all props were fine!
I did notice in the logs that the HDOP drops from 2.5 to 1.5 a few seconds before the roll and fall. Could it be linked?
Hope someone has the time to assist.
Cheers for now.
Jared
