I’ve connected the APM to the computer with the usb and connected the APM to Mission Planner (the baud rate is at 115200 and I don’t have an option to select Arduino Mega 2560 as its described in the guide but I can select the usb port which my APM is connected to).
Later on I’m just selecting the firmware, I can see in this screen that is detecting my APM, as I read Arduino Mega 2560. When I select the copter firmware its says Downloading (I can see a blue led blinking in the APM) and then I get a popup saying It couldn’t load the firmware to the APM.
I keep getting this time out message in the logs:
avrdude: stk500v2_ReceiveMessage(): timeout
And then the APM Planner crashes and I need to reboot the computer.
I’ve tried a different usb port, and I’ve installed the latest v I could find of APM Planner for mac but still no luck.
Any ideas?
I’m going to install a virtual box to install windows and download APM Planner for windows to see if I have more luck… Would be nice to figure out why I’m getting this error…
@Flipflop,
I suggest that you try and program your APM with MP as APM Planner 2.0 still has some growing pains.
You probably have a serial driver issue.
Regards,
TCIII GM
I gave up with APM Planner in Mac because I couldn’t get it working… Now I’m trying it in in windows using virtualbox and It seems to do the upload ok but it fails in the verification. :S I tried with different ports but same issue…
Wow you almost killed me! Finally got it working so the hardware is ok.
I gave up using VirtualBox and installed Win 7 ( ) in an old laptop and installed the firmware successfully using both mission planner and APM Planner 2.0.0. (I was able to connect the ardupilot in both)
However now, I would like to use APM Planner 2.0.0 in my Mac but if I click connect nothing happens I followed the installation instructions and still no luck. In the list of ports I don’t see any port with my ardupilot (I do see this in windows).
