APM 2.6 motors don't rotate
hi! i have a problem with apm2.6 with 3.2.1 fw, i do all the configurations (basic configurations to fly) now i can arm but when i throttle motors don’t spin. I calibrate esc manual (1 by one because automatic calibration with apm doesn’t work for me) why my motors doesn’t spin? thanks!
I would check the wiring to the ESC’s to make sure you connected them correctly to the APM. In Mission Planner there is a motor test that should spin each motor. You may have to adjust the percentage to get the motors to spin.
Mike
thanks for the info probably this is my problem, i will check it!
