I am unable to upload firmware to my APM 2.6 with my mac.
The usb cable clearly works… for the Flight Data Screen in APM Planner 2.0 shows the gyro, compass, and gyro data correctly.
When I go to the “Initial Setup” button and “Install Firmware” and then “ArduCopter V3.2.1”… I get the following:
Started downloading firmware.diydrones.com/Copter/st … Copter.hex
Finished downloading /var/folders/gn/yrls614j0bl0sqtcbk3wcfh80000gn/T/APM Planner.lIi888
Opening firmware file…
Hex file loaded: 242280 bytes
Unable to open COM port: usbmodem1411
Here are some of the facts:
- I’m running a Macbook air with Yosimite 10.10.2
- My APM 2.6 is brand new.
- I’m running APM Planner 2.0.18
- I did install the FTDI drivers.
- When I look at system info… under usb… i see “Arduino Mega 2560”.
- I’ve tried with multiple usb cables and multiple macs.
- And again… if I connect to the device… the flight data comes across no problem.
- When I try to install the firmware… I always get a popup which says “Unable to open COM port: usbmodem1411”
I’ve googled for hour and can not find a solution. Any help would be greatly appreciated!
Thanks
Stephen
