I’m playing with CANFD, running master on fc and ap_periph 1.4 on node, when I turn on canfd and I can connect to slcan either through mission planner or dronecan_gui but the node shows up but not with the periph name and I can’t get parameters. With fdcan off the node works fine.
I have selected the node in fdcan mode and I can see baro pressure in the subscriber so it must be working. Any help would be appreciated.
I’ve just released AP_Periph 1.4.1 to fix an issue with compasses on peripherals. The only change is a fix for an issue that caused compass data to be all zero.
Fix is building on the build servers now.
I am setting up a large VTOL plane and am struggling to get I2C compasses to be visible on the canbus.
I tried 1.4.1 and also the latest 1.5 and neither seem to register that a compass is connected.
Using a holybro F9P with IST8310 compass conncted to the UART port on an L431.
I have also tried other i2c compasses)
I can see the GPS great but the i2c compass does not register and does not appear in the HWID list in mission planner. I assumed the compass would be fairly plug and play.
Is there something specific required to enable these devices?
