Howdy,
I’ve been trying to get an antenna tracker going using the pixhawk method (without mission planner in the loop.) I’m currently using Antenna Tracker V1.0
Calibration and pixhawk orientation appear correct. I have an external GPS module and am using the compass on the pixhawk.
Here’s a pic of my setup:
The antenna tracker pixhawk is able to see the drone to be tracked. The mavlink ID of the drone is set as the target ID in the antenna tracker pixhawk’s parameters. The servos test fine with control through the pixhawk.
The behavior I am experiencing is that the antenna tracker system will scan like I assume it should. However, when it “locks on” it just stays fixed in place, even when the target drone moves. You can see in the screenshot what I have been seeing.
It looks like the antenna tracker has determined the heading which it needs to point to (the orange line), but it just doesn’t, as you can see by the actual heading (the red line).
I’ve experimented for a couple of days and have had no luck. Any help would be greatly appreciated
