Ant-433-wrt-rps
Saw this antenna on DigiKey and wondered if it would work with the 433MHz telemetry radios. It would look good on a plane.
https://www.digikey.com/product-detail/en/linx-technologies-inc/ANT-433-WRT-RPS/ANT-433-WRT-RPS-ND/2601674
Datasheet: https://linxtechnologies.com/wp/wp-content/uploads/ant-433-wrt-fff.pdf
I’m sure it would work if -.9dBi gain is OK for your use case.
I just noticed that, but thanks. The normal antennas are 2 or 3 dBi, right?
Yes, around there. There are some 5dBi claimed units. But maybe it can work for you depending on your range requirement. I use ESP8266 WiFi radios an several craft. Not so much for telemetry, although they will do that short range, but for general configuration and calibration purposes.
