I cannot connect with NTRIP. I have checked and double checked my log info. I can connect using u-center using the same info. It looks like all of the issues reported here are related to getting the log in correct but I get a different error whenever I intentionally provide bad information; I really feel the login data is correct. I do not know if there is anything in the config files that I need to change to correct this and the gps (f9p) is getting 3D fix and my CORS site is 5km away.
I have been stuck trying to fix this for few days, any help would be greatly appreciated
Could you check without hardware connected that you can get data from your caster ? Just launch MP, and in the RTK pannel, connect your endpoint. If it works, it should display the RTCM frame. Otherwise, you could have more info in the MP terminal on what is wrong and how MP is trying to connect
Points to check :
Ntrip v1 or ntrip v2 ? Mission Planner only use V2 for now, if you update to next beta, there is a tickbox for V1
Check your user string, if it got @ on it, replace it by -at-
Restarting MP with nothing connected. I tried to log in from the setup/RTK/GPS inject page.
Get the same error “Error Connecting” but the terminal panel looks like the ntrip may be connected (ntrip Open) but not communicating??
Not sure what to think about regarding Ntrip V1 or V2. Is that mav2 as shown in the terminal below? What should I look into to know?
The @ string is ok, The MP login does not like -at-.
I found the posts for older Ntrip casters; and installed the latest beta version of MP (build 1.2.8663.5522). I take it the difference between v1 and v2 is http vs htpps:
With a fresh install nothing connected, i seem to connect, but nothing populates on the RTK screen
I think v1 helps. Not sure now but i think its connecting and then disconnecting - maybe an issue with the internet connection?
I was able to solve my connection issue. I have always logged into the Ntrip server that was nearsest to me. For whatever reason, doing so now continually drops and restarts the connection. I still can log into other nearby mount-points and they work as expected.
So the problem connecting was a IP connection issue. I also learned that there is a different port/mountpoint that provides the “nearest site” automatically. This port and mount point stay connected and I get 6 green connections and strong signal…
Woohoo- a 7 day lesson learned. now on the the rest of the setup
