Another question that I can’t find an answer too.
I am wanting to use qGroundcontrol on various drones I have. However some have gimbals and some do not. You can configure the app to manage your gimbal or camera, record, stop recording and so on. But what i don’t get is whether this config once set is global or if in some way its model specific. If it is I have not figured out how that works. If it doesn’t then how does the community move the app from machine to machine if the config is different.
The answer is “it depends”. Application settings can be found under the “Q” icon. Anything in there would need to be replicated on a new computer. Vehicle settings, which are stored on the vehicle are found under the Setup Gear icon. Anything set there will remain even if you connect to the vehicle from a different computer.
