Hello, is it possible to center the OSD graphic relative to the center of the monitor, so that the crosshair is perfectly centered on the screen?
I am using a Holybro Micro OSD V2.0 board (connected via Telemetry 2 port to the Orange Cube+), RUSH TANK MAX SOLO VTX 2.5W image transmitter and a Skyzone Steadyview X image receiver.
However, I think it is impossible to do this on the Holybro OSD module, because the module has it’s own software and it’s functions are not supported by Mavlink using the OSD_TYPE; 4 parameter.
I belive this is because OSD has even numbers of characters horizontally. That makes imposible to put cross character exactly in the middle. It would require to have dual character cross.
I wonder about one thing, if I wanted the OSD to be fully supported from Mission Planner, would I be able to control this module from Holybro by uploading some software? There is very little information on this in the manual.
This is what the OSD configurator of this module from Holybro looks like:
