Hi everyone…I think I’ve found a bug. While flying inverted, the (analog) OSD arrow pointing in the direction of home points in the wrong left/right direction. And it also points “down” in the OSD, meaning in the image it’s pointing to the sky. I suspect the proper fix is to make the angle that it points dependent on the roll angle of the plane, but since most aircraft don’t spend a lot of time doing knife-edges we could just invert the arrow when the aircraft is rolled between 90 and 270 degrees.
I can picture this at the local RC Flying club:
Q “Why are you flying upside down all the time”
A “If I dont fly inverted the OSD arrows in my goggles point the wrong way”
I know - it’s not helping
