Thanks for the clarification. So when I blow over the pitot tube, neither AS or Airspeed value changed. However, the calibration data log shows ARSP matches closely with GPS calculated speed. Also, the offset and Aspect ratio changed during the calibration flight.
So does it mean Airspeed sensor working?
In your screen shot I’m guessing your powered by USB since the BAT voltage is so low. What happens when you power by a battery? Do you get airspeed then?
