the pre-processing step for AMSL geotagging using CAM messages shows this error:
Using AMSL Altitude True
Reading log for GPS Messages in order to get AMSL Altitude
Error System.FormatException: Vstupní řetězec nemá správný formát.
v System.Number.ParseSingle(String value, NumberStyles options, NumberFormatInfo numfmt)
v System.Single.Parse(String s)
v MissionPlanner.GeoRef.Georefimage.readGPSMsgInLog(String fn) v c:\Users\michael\Source\Repos\MissionPlanner\GeoRef\georefimage.cs:řádek 299
v MissionPlanner.GeoRef.Georefimage.doworkCAM(String logFile, String dirWithImages) v c:\Users\michael\Source\Repos\MissionPlanner\GeoRef\georefimage.cs:řádek 979
v MissionPlanner.GeoRef.Georefimage.BUT_doit_Click(Object sender, EventArgs e) v c:\Users\michael\Source\Repos\MissionPlanner\GeoRef\georefimage.cs:řádek 1476
In MP 1.3.37 it works OK. So I use this one until a fix is done in the latest MP.
Is it also possible to geotag TIFF (.tif) files too ? Because JPG is loosing quality… It would be fantastic if there would be this option for TIFF files that are exported from RAW.
How can you import 7000 coordinates from your BIN log into Photoscan in some realistic time when TXT log has JPG instead of TIF inside ? So I have to manually change file extension in this TXT in order to import this into Photoscan. It would be nice if TIF geotagging could be used without such problems…
I also experienced the same problems with the system geottaging In MP 1.3.19
Error System.FormatException: valuewas either too large or too small for an Int32.
at Sysyem.Number.Parselnt32(String s, NumberStyles style, NumberFormatInfo info)
at System.Int32 Parse(String s, IFormat Provider provider)
at MissionPlanner.Georefimage.doworkCAM(String logFile, String dirWithImages) in c:\User\hog\Documents\Visual Studio 2010\Projects\ArdupilotMega\ArdupilotMega\georefimage.cs;line 1074
at MissionPlanner.Georefimage.BUT_doit_Click(Object sender, EventArgs e) in c:\User\hog\Documents\Visual Studio 2010\Projects\ArdupilotMega\ArdupilotMega\georefimage.cs;line 2253
what happened with the system?
