Ambiguous things in QuadPlane failsafes
Hello.
https://ardupilot.org/plane/docs/qrtl-mode.html
in this page, it says plane will ascends to Q_RTL_ALT before RTL transitioning, if it is in VTOL mode.
https://ardupilot.org/plane/docs/quadplane_rtl.html
in this page, it says copter will decends to Q_RTL_ALT when entered in waypoint loter radius(or rtl radius)
so I have three questions :
(1) Q_RTL_ALT determines the altitude that VTOL climbs before transtioning when RTL, not ALT_HOLD_RTL? it will transit at Q_RTL_ALT first, and then climbs to ALT_HOLD_RTL?
(2) is that right Q_RTL_ALT determines two altitude? :
- the altitude at start point of RTL if it kicks in VTOL mode
- the altitude in the destination
(3) so, it is dangerous if there is lot of difference in ALT_HOLD_RTL and Q_RTL_ALT,
because the waypoint radius is not enough the plane to decrease altitude from ALT_HOLD_RTL to Q_RTL_ALT, its altitude decreases too fast.
(as decribed in picture)
I looked into Q_RTL_ALT paramter description here but there is only one brief description, which confuses me : Complete Parameter List — Plane documentation
do anyone know about this?
the descriptions of parameter is so ambiguous.
“The altitude which QRTL mode heads to initially”
is this right?
not
“The altitude which QRTL mode heads to initially, and altitude that aircraft heads to, before reaching waypoint loiter radius before arriving home.” ?
