Hi I was wondering if i can use a I2C temp sensor like this one https://learn.adafruit.com/adafruit-mcp9808-precision-i2c-temperature-sensor-guide/overview on a Pixhawk, What do ya think>?
Somehow it will be possible, for me a analog in was the easiest way.
What Analog sensor did you use? and is there a way to have it display the temp on a Minim osd? currently i am reading the Pixhawk board temp with the OSD, Basically i would like to have it seen as temp with mavlink as temp instead of the board temp
I use a EPCOS 100K Thermistor. Its often used on 3D printer like on RAMPS Boards.
I see it as current or voltage for the second battery monitor.
