Why does my Pixhawk always fail the Brownout and PM test when I run Auto Analysis? Log file attached.
Here are the test results from the LogAnalyzer window:
Log File C:/Program Files (x86)/Mission Planner/logs/QUADROTOR/1/2015-09-07 12-58-30.log
Size (kb) 3944.1044921875
No of lines 52697
Duration 0:03:43
Vehicletype ArduCopter
Firmware Version V3.2.1
Firmware Hash 36b405fb
Hardware Type
Free Mem 0
Skipped Lines 0
Test: Balance/Twist = GOOD -
Test: Brownout = FAIL - Truncated Log? Ends while armed at altitude 3.73m
Test: Compass = GOOD - mag_field interference within limits (2.49%)
Test: Dupe Log Data = GOOD -
Test: Empty = GOOD -
Test: Event/Failsafe = GOOD -
Test: GPS = WARN - Min satellites: 6, Max HDop: 3.47
Test: IMU Mismatch = GOOD - (Mismatch: 0.39, WARN: 0.75, FAIL: 1.50)
Test: Parameters = GOOD -
Test: PM = FAIL - 22 slow loop lines found, max 10.40% on line 1208
Test: Pitch/Roll = GOOD -
Test: Thrust = GOOD -
Test: VCC = GOOD -
Mission Planner 1.3.31 build 1.1.5696.33420
