Hi guys,
I’m getting a very strange behavior when I enable the AltHold mode (or loiter…), my copter don’t stabilizes at all the altitude, getting big oscillations in altitude. In the first flights the behavior was a little better but i heard a constant “pulsing” noise from motors when AltHold activated.
The barometer is covered with foam, the apm case have black tape to avoid light, and my vibrations are under control ( I guess…).
In the previous firmwares the machine was flying great in all modes, now with 3.1 stable I’m desperate with this issue. I tried to play with Alt_Hold value, and tuning down the THR_ACCEL_P to the min value of 0,450 (default is 1,000) but no luck.
I have here a dataflash log (with IMU enabled) that you can analyze to tell me if I have some problem in my setup.
Thanks in advance!
