Hello guys, I’m here again. I got a weird problem, when i run motor test no axis vibrating at all, looks everything perfect, but when i use RC and trying to takeoff with it, or even without wings on the table, it’s vibrating and i can’t manage why is this. Can someone help me to fix that weird thing? Thanks already.
Set LOG_DISARMED to 1 and post a .bin log file with one of your takeoff attempts
Oddly I getting the same issue today on a new build. Seems to be a issue when powering down the throttle with a nasty vibration.
Classical frame resonance at low frequencies
I think so as well. I will get it the air as see if it goes away, The new LWPLA is light as can be.
Hello @amilcarlucas , here is the file without wings, i did motor test and RC, so with motor test working perfectly, and with RC all 4 axis tubes Vibrating. https://file.io/NK6Hcan3Si4X. Thanks for the time.
Hi I have something for you to try to remove the shutter if ya like. Go to the Roll /Pitch Sensitivity menu and move the slider to the left at .0321 I was able to smooth out my motors on the maiden.
