Hey everyone,
I am working on getting an align 800 fully autonomous.
And given how little support there is available I figured I would post my logs and experiences up to help anyone else who is considering this. My log is below:
docs.google.com/document/d/1tg0 … sp=sharing
I will post the gains I am using once I connect to the pixhawk again this afternoon.
A couple of questions, the heli seems to bounce after a pitch movement in a hover, i.e. I do a hard forward pump on cyclic and then it seems to bounce a tiny bit while it is trying to converge, is this a P or an I gain issue? I’ve backed the I gain down and have started on the P but I can’t quite tell if its helping. I am unsure if it is the P because when I observed that on the roll axis, having too high a P didn’t make the oscillations converge, they seemed extremely underdampened and would worsen with time.
My I gain on the pitch is .15 currently and I believe the P is about .07 but I may be mistaken on that.
Another issue I noticed is that the collective behaves funny, the helicopter seems to ascend and descend by about a meter each direction during a hover, I am conscious of my stick inputs causing this but I can’t tell if it is because it is too touchy or if it is because the response is too slow and the gain inside of my brain is too high. Does anyone know which parameter I can adjust to edit these behaviors?
My last question that is much simpler is: what is the FF tuning for? I can tell that it helps, but I want to understand it better so I know what exactly look for in the heli’s behaviour.
I can keep posting updates if anyone cares to hear them, otherwise I’ll just post questions
Thank you,
Sebastian
