Airspeed sensor influences pitch reading (Bench test: More pitch jitter in 4.6 DEV compared to 4.5.4)
Hi, I came across this and found it odd. Maybe it’s perfectly normal. But I thought I’d share.
While the plane is sitting perfectly still on the floor, with 4.5.4 in the 20s test, the pitch moves up and down roughly between -0.080 and -0.096. But with a custom build (master as of 2024-07-15), the jittery pitch is much more noticeable. It goes up and down between -0.42 and +0.11, so that you even notice it in Mission Planner’s attitude indicator.
4.5.4: https://youtu.be/jIqlMrCv3q0
4.6 DEV: https://youtu.be/vy-bITmQxpk
Hardware is SpeedyBeeF405WING.
Simon
Just tested: 4.5.5 beta doesn’t have this jitter.
Can it be that this is just because in the DEV custom build, I have support for the airspeed sensor and in the other versions, the sensor is not sending any data? (See earlier thread.)
Simon
Apparently this is related to the airspeed from the pitot sensor that somehow spills over into the pitch reading when stationary on the ground. This is a same with a custom build of 4.5.4 with my airspeed driver enabled.
But I guess, this is not really an issue because once in the air, the airspeed reading is more stable and external factors will cause much more changes in pitch. :wind_face: :small_airplane:
Please set LOG_DISARMED to 1 and post logs from both test cases and if you can also 4.6 with airspeed disabled.
Sorry, tlogs (telemetry logs) are of little use as due to bandwidth limitations there is little IMU data
OK, I should receive a SD card for this FC today or tomorrow and will take new logs then. Simon
Card arrived today. I took two logs. One with ARSPD_USE 1 and one 0. Here you go.
