My logic tells me that if you want complete control even at zero throttle, the second if shall have && rather than ||. Am I missing something, or is this indeed a bug?
@andyp1per, git blame attributes that line to you. Could you please check this?
My impression is that, whenever you are in Acro and have AirMode on, you want to have full control even at zero throttle. In my experience, there is indeed some authority loss when falling from the sky. Some of my chat fellows report similar experience.
@maxbuzz great catch - @andypiper you might remember I tried increasing MOT_SPIN_MIN a few months back because I thought my 7" didn’t behave well at zero throttle. Hope this is the answer…
@Leonardthall@andyp1per I have recently found that RCx_OPTION=154 “Arm/disarm with AirMode on” does not work for Stabilize. This was first found out from experience, and then I could not find a code path that would do it.
Is that intentional? Does that not conflict with e.g. documentation here (Stabilize Mode — Copter documentation)? The separate RCx_OPTION=84, on the contrary, works for Stabilize.
