Hi all,
I have a problem concerning ailerons, for which I hope to receive some advice in order to solve it.
First, gear used:
Matek F405 wing f.c.
MiniTalon
Futaba TG14SG Sbus with S-FHHS receiver.
Servo Output set in Mission Planner:
SERVO1 THROTTLE
SERVO3 AILERON
SERVO4 AILERON
SERVO5 VTAIL LEFT
SERVO6 VTAIL RIGHT
Servo connection on Matek F405 wing
S1 throttle
S3 aileron
S4 aileron
S5 left tail
S6 right tail
Flight Modes associated to a 3 way switch:
Maual
FBWA
Loiter
The problem:
there is no way to regulate ailerons in differential way although they are associated to different channels , nor to use different endpoint/trim (on the radio). Only one channel works for both ailerons, as they were connected to the f.c. by a Y cable.
As a check I connected the servos directly to the receiver, by-passing the Matek board, without modifying the settings on the radio, all endpoints,trims and differentials could be set without any problem.
I checked many times the configuration on Mission Planner, in order to verify I missed something, but everything seems ok.
I wonder if I’m searching for something that is not applicable to all the stuff above, but I didn’t know it.
Anyway thanks forward for any advice that could help
Corrado
