I think that my flaperons wiring on RC outputs is wrong : the two flaperons are connected to RC5 and RC6 at the right side of the RC1 aileron output ?
I have tested, they are no signal on RC5 and RC6 outputs, I don’t understand why
RC5/6 FUNCTION 24/25 FLAPERON_OUTPUT 1
the RC5 input works
I have tested, they are no signal on RC5 and RC6 outputs.
I can’t found the problem, could you help me please ?
I recommend you write a well-organized and detailed request for help. Start from “the beginning” by describing your setup and desired behavior. Next include the details of what you tried that worked (and didn’t work). Specifying to the processes and information that you followed from the main documentation will help others understand why that didn’t work for your case, and how to assist you.
The ailerons work with ELEVON_OUTPUT option, but the flaperons don’t move with Flaperon setup of “Flaperon Configuration” doc http://ardupilot.org/plane/docs/flaperons-on-plane.html#flaperon-setup
I need to move the ailerons on others pins ?
I think that the problem is that I have two servos dedicated to flaps, and the documentation explain to use only 2 servos for flaps and ailerons “Flaperons use your 2 ailerons”
How can I set my 2 others servos only for flaps ?
