So yesterday i did 2 perfect flights without any issue (as always) but in the last one i got the GPS-2 Error (Error Pos Horiz Variance) in the first lane of the auto mission.
Fortunately the drone didn’t crash and finished the auto mission and didn’t showed any more error.
Any idea what could be?
I use the Here+ RTK-Base and Here+ GPS Rover.
Was very windy (25kmh/30km/h).
Please please please, post bin log, not the text one…
It seems you lost gps reception momentary, and not only at the beginning, but twice more at the end.
I would suspect an electrical error (intermittent contact, or cold joint, bad connector).
The last two was not long enough to cause error, but you lost all sats for a short period twice at the end.
check GPS/NSAT and GPS/HDOP.
Check your older logs as well, perhaps the problem is not entirely new.
Already did that a few times and didnt got any ‘‘gps error’’.
I’m starting to think that could be a problem related to the RTK Base -> Rover bad setup (was in an hurry - and maybe i didn’t do the correct steps in the GPS / RTK Inject tab) in that last flight.
Usually when i use RTK Base -> Rover i wait till its FIXED and i got, EVERYTIME i fly, in the HUD 13SAT max. In the GPS / RTK Inject tab i have ALOT more satellites, ofc.
In that last flight i didn’t waited for FIXED and the HUD was saying 18SAT, like i was using only the GPS in the Rover without any RTK Base.
So maybe it was a bug / issue with the Pixhawk didn’t knowing what GPS should use, if the GPS in the Rover or the RTK GPS Base.
Sorry if my english inst the best to explain correctly.
The ‘‘error’’ its in the printscreen above. It looks like the drone was using, for a few seconds, a difference reference. RTK GPS coordinates vs GPS coordinates?.
This does not explain the total loss of GPS reception. Bouncing between rtk-fix and float can cause a slight change in position, but never a lost of sats. I still think you have a HW issue.
I with you in that RTK FLOAT to RTK FIX, the bouncing is zero (already happen multiple times and zero issues).
But what i’m saying is RTK FLOAT / FIX bouncing to GPS NON-RTK (3D FIX / 3D DGPS).
Next monday i’m gonna do some tests and see what happen.
Ps. the cable between gps and pixhawk 2.1 was ‘‘loose’’ (so i tight it with some tape) - so with the speed forward (12m/s) plus wind against it, maybe could do some strange moves in the cable and could be it.
