New user and trying to get into automated aerobatics. I am able to fly missions with the aerobatics script in SITL using plane 3D and 4.5 firmware, and I can get missions to run in Real Flight 9.5 with Flight Axis but aerobatic scrtipts do not run. Trying the same with Plane 3D does not get me control in real flight.
So any help in figuring out how to gew the aerobatic scripts to run in Real Flight would be appreciated.
Thanks,
Stuart
I did get a loop to run. Seemed to be an issue with the flight plan getting to the right point in space. When trying to run a full aerobatic sequence which works well in Mission planner under Plane 3D I am getting this message
Lua: ./scripts/plane_aerobatics.lua exceeded time limit
And the script is skipped.
Appreciate any help.
Stuart
I am facing same problem. Unable to understand why I am running into the same issue even on SITL.
