Hi, I’m thinking of a new fpv plane build with probably a H7 FC probably Matek H743 wing controller. Will I be able to connect using Bluetooth or WiFi to mission planner and will this need an extra module? I only have experience with a Speedybee f405 wing which comes with a usb/Bluetooth/WiFi board. I’ve been offered a used pixhawk 4 but suspect it would be better to go with newer technology.
Hi Philip, if you resd the specifications of the Matek H743 Wing on the offical homepage of the manufacturer you will see what the board has. All what is not shown is not included. If such a board has inbuilt Bluetooth/Wifi thes will be shown for sure. And this is with all manufactures, theey all will show if they have such functionality.
The Matek H743 Wing has no inbuilt radio communication but it is possible to add this functionality by external modules.
