Its an ADTI one. It work out to flat 35mm but its terribly blurred and distorted around the edges. It honestly took me about 9 hours to focus. And Im still not sure its really focused.
I doubt the camera will be improved much nor support. The company appears to be run on a “stick” approach rather than a “carrot” method.
I have used the foxtech mapping camera. Map-01. I found it to be similar to what you describe above regarding ADTi cameras. I guess just vanilla sony cameras are better then.
“…it seems like the only way to do it is to take a photo, take out the card, read it to verify the focus, then reinsert it in the camera, adjust the focus slightly, take another photo and repeat…”
“It honestly took me about 9 hours to focus. And Im still not sure its really focused.”
Hi Luke, have you tried using a monitor via the HDMI output to focus your images? Once you find true infinity, you could then tape the focus ring in place, or mark the barrel.
