Hello everybody,
I am trying to send a custom ADSB_Vehicle message from my raspberry Pi to my Pixhawk4 via Telem2 port using the mavgen C library. I can perfectly request data streams, send and receive GLOBAL_POSITION_INT and HEARTBEAT messages.
But when i try to send a ADSB_Vehicle message it seem so never exit the raspberry pi. I cant see it on the mavlink inspector nor the simple “show every received mavlink packet” script on the pi.
I have tried things like adding changing system and component id or adding1Hz heartbeat messages.
I have a µAvionix ping that i tried to mimic the behavior of, without luck.
Thanks for your help!
Code:
#include <mavlink.h>
#include <errno.h>
#include <fcntl.h>
#include <string.h>
#include <termios.h>
#include <unistd.h>
mavlink_message_t msg;
int main()
char *portname = "/dev/ttyS0";
uint16_t len = 0;
int mavLinkStream = open(portname, O_RDWR | O_NOCTTY | O_NDELAY); ///dev/ttyUSB0 oder /dev/ttyS0
sleep(1);
if (mavLinkStream == -1)
printf("[ERROR] UART open()\n");
else
printf(" UART ist open() \n");
struct termios options;
tcgetattr(mavLinkStream, &options);
options.c_cflag = B57600 | CS8 | CLOCAL | CREAD;
options.c_iflag = IGNPAR;
options.c_oflag = 0;
options.c_lflag = 0;
tcflush(mavLinkStream, TCIFLUSH);
tcsetattr(mavLinkStream, TCSANOW, &options);
sleep(1);
char buf[40];
//request gps data stream
//mavlink_msg_message_interval_pack(1, 1, &msg,MAVLINK_MSG_ID_GLOBAL_POSITION_INT, 10000); //Cleaner solution, does not work however.
//mavlink_msg_request_data_stream_pack(27,27, &msg, 1, 1, 0, 1, 1); //request data stream All(0) (depricated function but works)
//len = mavlink_msg_to_send_buffer(buf, &msg);
//write (mavLinkStream, buf, len);
len = mavlink_msg_adsb_vehicle_pack(1, 1, &msg, 4251708, 495795456, 197686112, 0, 741400, 16000, 10000, 1200, "aaaaaaaa", 3, 1, 415, 0);
//len=mavlink_msg_global_position_int_pack(255,0,&msg,1234,47,11,260,10,0,0,0,UINT16_MAX); //this line works
char bufsend[len];
printf("message prepared: ID %d length: %d", msg.msgid, len);
len = mavlink_msg_to_send_buffer(bufsend, &msg);
write(mavLinkStream, bufsend, len);
return 0;
