I spend a lot of time to get all running. Now I’m struggling on the Servo Output
Ground Steering works but I did not get the throttle output.
I use the 3.5 Version of Rover. Frame Class 2
Need more info. Did you arm it? You have a parameter list?
Sorry not shure how to arm it.
full.param (17.2 KB)
Hold your rudder stick to the right for a few seconds should arm it. You can change ARMING_REQUIRED to 0 to skip needing it armed for now.
Thanks a lot.
it works,
