I want to simulate a drone with gimbal using ROS in Ubuntu,
I am new in these topics,
I could not be sure about procedure that I should follow,
Where should I start ? Could you help me please ?
Best regards,
The wiki is you friend ! http://ardupilot.org/dev/docs/sitl-simulator-software-in-the-loop.html for the simulation, http://ardupilot.org/dev/docs/using-sitl-for-ardupilot-testing.html#adding-a-virtual-gimbal for virtual gimbal and http://ardupilot.org/dev/docs/ros.html for how to connect with ROS !
Hello @khancyr,
Thank you so much for your answer,
After see map and console I tried directly Adding a virtual gimbal part and then I got error ‘‘unable to find parameter RC6_FUNCTION’’ for each one.
Specify a servo-based mount:
param set MNT_TYPE 1
Set RC output 6 as pan servo:
param set RC6_FUNCTION 6
Set RC output 8 as roll servo:
param set RC7_FUNCTION 8
I searched but I could not find any good solution,
Is there any missing part? I dont know what is the problem,
Best regards,
