Hello! Is there any specific reason to check only ACRO_RP_EXPO parameter’s value when transforming pilot’s roll pitch and yaw input into a desired lean angle rates? This is because ACRO_RP_P parameter also affects the desired angle rates.
// range check expo
g.acro_rp_expo = constrain_float(g.acro_rp_expo, 0.0f, 1.0f);
// calculate roll, pitch rate requests
if (is_zero(g.acro_rp_expo)) {
rate_bf_request.x = roll_in * g.acro_rp_p;
rate_bf_request.y = pitch_in * g.acro_rp_p;
} else {
// expo variables
float rp_in, rp_in3, rp_out;
// roll expo
rp_in = float(roll_in)/ROLL_PITCH_YAW_INPUT_MAX;
rp_in3 = rp_in*rp_in*rp_in;
rp_out = (g.acro_rp_expo * rp_in3) + ((1.0f - g.acro_rp_expo) * rp_in);
rate_bf_request.x = ROLL_PITCH_YAW_INPUT_MAX * rp_out * g.acro_rp_p;
// pitch expo
rp_in = float(pitch_in)/ROLL_PITCH_YAW_INPUT_MAX;
rate_bf_request.y = ROLL_PITCH_YAW_INPUT_MAX * rp_out * g.acro_rp_p;
Extracted from “ArduPilot/ardupilot/blob/master/ArduCopter/mode_acro.cpp”
