As recommended, I calibrated my accelerometer on the bench ( worked), then reinstalled it in the airframe. Now I seem to be back to go. How do I know if it’s still holding the calibration? I see no indication of whether or not any of the mandatory hardware remains calibrated after a shutdown and restart. Newbie, -true. Do I just assume all is well here?
Yes. Calibration data is stored, so you should be all good to go.
(As far as accelerometer/gyros. You still need radio and mag calibration, etc …)
Thanks, Olivier. Been using Qgroundcontrol, and there’s the green dots that let you know that calibration has been performed and retained.
